Problem in my windows XP operating system after installing new software
I have a problem in my windows XP operating system after installing new software.
New Software’s are not working properlyÂ
This is basically due to some virus program and you have to uninstall your software and try to re-install it.
Try to install 2 or 3 software and if issues persist, then you have to use some virus removal program for scan your computer or you have to format your hard drive and reinstall your OS.
Try Kaspersky Virus removal program for better solution.
Thank You
John Major.
There are many causes for the software's impracticability. The causes may be:
* The software doesn't support windows xp
* Some utilities are missing to run the software
* The proper program language redistributable package is not installed.
* Some files are missing in the directory.
* The software contains virus so that firewall program is not allowing the software to run.
* The program is infected with any virus that is staying in your pc.
* The software was not installed correctly.
For these reasons, many types of software don’t work properly even run.
You should:
* Find out the software's system requirements and update your pc according to the configuration.
* Scan your pc for virus.
* Re-install the software.
* Clean up your pc with any good pc cleaning tool.
After doing all these things, the software must run properly.
