I have a problem with my Nokia 500. I used fontzoomer lite (downloaded from ovi store) to change my device system fonts. It worked great(only some problems with symbols).in another way (which I found in a site); I copied font from my laptop' and renamed as in z:/resource/fonts/ and paste it in f:/resource/fonts/ and restart my device. It also worked, but now when i using fontzoomer to back to default fonts or any other fonts it is not working. It displays "do u want to apply changes? phone will be restarted(if required)." As I select yes device restarts but font remains the same. What should i do?
Help please!!!
Problem with Nokia 500 fontzoomer.
May be this is happening because you have changed system font completely. Your phone is using your system font cache. You need to reinstall Font zoomer. If this problem persists, then restore your phone.
Restoring will solve your problem. Your system font will restore after restoring your phone. After restoring, You can use font zoomer again. Keep a backup before restoring your phone.
Hello Bart Fuentes,
           If you want to change your system fonts then you have to download themes for your NOKIA 500. They are easily available and can help you in getting that font which you like you can also edit these themes so that you can make it according to your need. There are many themes in the market that can give you your required specifications.Â
You can also restore your phone in the previous state by just going to the setting menu and after that you need to click reset settings. That thing can help you to bring you back to the original state of your sell phone without any loss of data.
