Hi everyone,
I am using Nuance PDF viewer on my Windows XP. I used the nuance PDF preview for PDF files. It was working perfectly few days ago. I have also installed Nuance PDF Toolbar plugin. Now recently I have updated my Internet Explorer from version 8 to newer version 9.
My problem is that whenever I tried to create a PDF file using the Nuance tool bar plugin, my I.E9 got corrupted. It stops working and hanged for a long time. Please help me how to get rid of this problem.
Your suggestions and tips will be highly appreciated.
Problem with nuance PDF preview.
Hello Gregory,
This is very well known problem and unfortunately there is not much to do at this moment. Hopefully, the bug will be fixed in a few days.
You can try reinstalling your PDF viewer for the beginning or updating the version if the newer version is available.
Besides that, the only thing to do is to make sure your Internet security settings are set at Medium. You can find that option under the Tools menu – Internet options.
The reason could be because of using Internet Explorer 9 with Windows XP.
The IE 9 works properly with Windows 7 or Vista or Windows Server 2008.
ORÂ
You may try to fix it by opening Internet Explorer in no add-ons mode.
To start Internet Explorer without add-ons, follow these steps.
a. Go to Start Menu, and select All Programs.
b. Click Accessories, and select System Tools.
c. Click Internet Explorer (No Add-ons).
Laz Zebbena
