Problem Occurred After the Deletion of Wireshark
I needed Wireshark for a short while. So I downloaded and I had it on my computer while I needed it and then I deleted it.
However after the deletion of Wireshark, my system showed this error on startup, which is weird since I already deleted the software: Library/StartupItems/ChmodBPF has not been started because it does not have the proper security settings.
I double checked, none of the Wireshark files exist.
Please let me know if you have a solution in mind.
Thanks a lot.
Answered By 0 points N/A #154826
WIRESHAK ANTIVIRUS is a fake virus removal program that is designed by Intruders to steal your Money through 3 different Tactics.
1. Fake Alerts and Warnings.
2. Misleading Scan Results.
3. Professional Looking Interface.
So GET RID OF IT IN MINUTES.
Delete Wireshark Antivirus for good so use trusted removal for any software website so download Spyware Review and also follow the instruction to remove this antivirus from your computer.
So step 1 is:
  • Click start run type command and press enter.
  • Command consoles "black window" opens.
  • Type notepad and press enter.
  • Type all text below in notepad.
  • Save this as a fix.
  • Right to your desktop.
  • Double click fixes. Right and click yes to conform.
  • So if you can't fix it then you need fix.zip so download Malwarebytes anti-malware from search engines.
  • Once it download then close all programs and windows on your computer.
  • Then run the setup of Malwarebytes anti-malware and install them.
  • AS Malwarebytes anti-malware will automatically update itself after install you can press the OK button to close that box and then you reach the main menu.
  • Then click on the scan button to start scanning your computer.
  • After scan finished click on show result button and remove your all infected files pressing the button removes selected.
  • After the removal of files your computer is restarted and your problem is solved.
I hope your problem is solved.
