Problem occurred on ActiveX Control
My warm greetings to all readers in techyv.
I have some issues here to consult. This is about my problem regarding ActiveX function. Whenever I am working on my Microsoft Access task that involves an ActiveX, I receive an error message. Please see below the error message for your reference on the problem.
Microsoft Access
The expression Mouse Move you entered as the event property setting produced the following error: A problem occurred while Microsoft Access was communicating with the OLE server or ActiveX Control.
* The expression may not result in the name of a macro, the name if a user-defined functions, or [Event Procedure].
* There may have been an error evaluating the function, event, or macro.
This problem I've encountered does not just happen on mouse activity, but to all scenario that requires the aid of ActiveX. I already re-installed the ActiveX component in my computer, but same problem persists.
Please write some comments.
