Problem occurred while using Microsoft Office 2007
Recently I have installed MS Office 2007 in my computer.
Sometimes I face acute problem running the program.
While trying to open any MS Word file either new or existing one I am facing this problem.
Besides an error code is displayed on the screen showing  " Windows cannot access the specified device,path, or file.
You may not have the appropriate permission to access the item".
How can I solve this problem?
Best Answer by micheal austin
Answered By 0 points N/A #112462
First of all you disable your Virus Scanner program, mostly the Virus Scanner runs automatically whenever you start your computer, the reason I am suggesting you this is because Virus Scanner makes your access permission disabled and whenever you open that file it show the message” Windows cannot access the specified device, path, or file.
Secondly, try to open the Word file by right clicking on the icon and select “OPEN”.
At last I would recommend you to use special software like Trend Micro Internet 2007 and you can also search more software which can protect your files and identity.
Answered By 0 points N/A #112464
Microsoft Word 2007 version is a built-in version where there are some opportunities to use graphics or image to makeup text. Here is some graphical mode to makeup any type of text by use of graphics or image,use of shape,use of 3D by which complex work can be done.
This is an user interface MS Word software Someone told about MS Word as an unlimited information processor. MS Word has capacity to create automatic page.
MS Word can edit webpage design and make able to go any file by help of Hyperlink in MS Word. Generally when installed Windows it is installed MS Office full version folder.
It is found installed necessary software MS Word, MS Excel, MS PowerPoint MS Access etc. under MS Office. Properly re-install MS Office 2007.
