Did you try to download the correct version of BIOS for your Zenbook? If not, then try to download the update from ASUS website. And then, save the downloaded update to your drive C: and restart your computer.
Upon boot up, press the F2 function key to launch the BIOS setup. Select the Advanced option and then launch the Easy Flash. The update will start the installation process. Follow the on screen instructions. Your BIOS will be updated to version 207.
The first thing you will need to do when you want to upgrade your BIOS to the latest version is to do it the safe way. It is very easy to brick your BIOS if you use the WinFlash utility from Asus Support. Use the following procedure:
First, you will need to format a USB drive to FAT32 format.
And then you will download the new BIOS and unzip it to the USB drive.
After that you will remove USB drive after you are sure that the file transfer is complete.
And then you will reboot the notebook and while the ASUS logo is on the screen, you will press F2 or del a few times to enter the BIOS setup.
After that look for the Easy Flash Utility and then insert the USB drive. You should tell Easy flash where your BIOS file is then follow directions.
After the notebook restarts, you will need to enter the BIOS Setup utility again and then choose "Load Optimized Defaults"
And then Save and Exit, then continue into Windows.
WinFlash is used to update the BIOS of a computer. If you already updated the BIOS then there’s no need to run WinFlash anymore because the BIOS is already updated. You receive that error maybe because you downloaded an older version of WinFlash which updates the BIOS to a much older version which is not possible.
ASUS ZenBook UX31E laptop
For ASUS ZenBook UX31E laptop, a much newer version of the BIOS is available. To update the BIOS to the latest, go to ASUS ZenBook UX31E BIOS and Firmware and download “Version 214”. To download the complete set of drivers for your laptop, go to ASUS ZenBook UX31E.
Just select your correct operating system from the dropdown list then download and install all necessary drivers for your machine. If you still can’t install the latest BIOS update in the download page, just stop updating the BIOS if your computer is working fine. If you corrupt the BIOS, you will end up buying a new laptop.
1....
