Gajora Sam
Posted on - 03/20/2012
I was using office 2007 before but when I reinstalled windows xp SP2 version, it says installation error which is setup cant found file and the file name which it shows is dwtrig20.exe but I have this file present in the folder.
Does anyone know what may be the problem and the probable solution.
Problem with office 2007 installation
Hey Gajora Sam!
It seems that dwtrig20.exe file is corrupted or damaged that is the reason Microsoft Office Setup cannot find this file.
There are two options for you. Let us start with first option.
If you have Antivirus:
Most of the time the virus makes our .exe files infected which later on blocked or remove by the antivirus. May be this is the reason that your dwtrig20.exe file is blocked or remove by your antivirus.
Old Version:
Second option is old version. May be your version is not compatible with windows.
Anyways in both of the cases you have to download a fresh copy Microsoft Office. After downloading it, install it. It will be install without any error.
Thanks
