Problem with office word 2007 startup command
I am having trouble with opening ms word 2007 with the winword command. Each time I try to access ms office word with the command it shows an error I do not understand. Should someone know to solve this problem kindly help me getting rid of this problem.
Arnold Huang
Answered By 0 points N/A #109853
You did not mention that MS Word 2007 was running well with your computer or from the very beginning after installation. If you were doing well with your MS Word 2007 it seems that some program files are missing from your respective program files unintentionally.
There may be a problem created by Virus. You are suggested to use an updated version of Antivirus for smooth functioning of your computer. If it is just after the installation of the MS Office program it seems that MS Office program was not installed properly.
However, you have to install the MS Office 2007 once again. You should take care while installing the program.
I hope you understand it.
Thanks
