Problem with open source SMTP newsletter while emailing
Hello expert, I am using windows 7 on my lap. I have installed a free communication software that open source SMTP. But I have a problem with open source SMTP newsletter while emailing. I cannot view the sent newsletters. Please can you help me to solve this problem? Thank you.
Answered By 0 points N/A #164201
Server differs depending on what email set-up you are you are using, better check the configuration settings of it. For example, if you are using the GMAIL server for your SMTP. Do not save the sent messages in your server, Gmail SMTP server will automatically saved in sent item folder. To be more safe, you should synchronize your draft with your GMAIL 's web interface by setting it in your draft item folder.
