Problem with opening PDF files
I received a PDF file as an attachment of an email. But problem is I am not getting the option to open it with Adobe Reader. It just opens with notepad. How can I solve this? Thank you
Best Answer by Rheanne Scott
Answered By -5 points N/A #120434
The advice that I can think of that you should try reinstalling your adobe reader. Don’t forget to delete you configuration file, and every file. You can find this in program files. You should try the new version it’s called X, and it has really good browser integration. If this doesn’t solved your problem you can try installing a new web browser. I can recommend Google Chrome, which is really compatible with Adobe Reader. If this is not helping then you can try opening the file with the open with functions that you receive by right clicking the file that you need to be opened.
