Problem opening Word Documents in Windows Explorer
I’m having trouble opening a Word document file through Windows Explorer; it takes time to open it and if I will click the file again it will just froze up and of course I can’t do anything with it but to forced close the file and it will automatically close the Windows Explorer too. But if the file will be open through the Office Word directly, it works as it is. I’m using Office 2007 in my Windows XP Professional SP3 computer with latest versions and updated security program. I already tried to uninstall and re-install the program and run a diagnostic test but there are no existing issues. This happens with my MS Excel as well. Can you please help me fix this?
