Hi techyv,
A problem in outlook 2010 trying to save HTML. is it possible to save an HTML file in Microsoft Outlook software application?
How can be this Ms Outlook application is related to those HTML files?
I am very curious about how two different applications can be merged or be related to each other.
I need some explanation.
Hoping for your help.
A problem in outlook 2010 trying to save html.
Hi.
Yes you can save the HTML file in outlook but for that you must have to use (.eml) extension.
And i am guessing you want to send email wd outlook so this is possible but you have to use EML extension with it.
And if you are downloading an email with outlook then double click and go up to Save -> Save As and under the file type choose Text .txt .
This is the same as EML format, you can just change the file extension from .txt to .eml
And to know about compatibility of these software please visit this link and study it
