Hi!
We have a problem here to pack Microsoft Publisher 2010. We get an error message here.
The error message is 'Error 1308. Source file not found: Y:ThinAppsProdPublisher 2010EQNEDT32.exe' it pops up when testing the app.
Is there any way to pack this software successfully?
Problem to pack Microsoft Publisher 2010
Hello Genelyn,
I have read your concern regarding Microsoft Publisher 2010. You were saying that everytime you test the program, an error will show and you are asking on how to fix it. Is it right? Receiving error codes when running a program means a serious problem has occurred on your computer, specially this error code you are referring to. You should put in mind that once this error occur, fix it as soon as possible because it will retain on your computer forever.
In repairing this error, you need to install the “Publisher Software Update” and the “Error 1308 Microsoft Publisher Fix.” To gain it on your PC, you may download it from Microsoft Official Download Page for free. Error 1308 usually occur when your system is being affected by a harmful virus, so you also need to have an antivirus installed in the system.
For you to successfully fix the problem, you must first run the “Publisher Software Update” then check the system for viruses with your “Antivirus” and then the “Fix Tool” to fix everything that has been mistaken or mislead in the program.
I hope I am in the right track of understanding your concern and give you a hand to fix the problem. I hope this information is of good help.
Mali
