Problem with Paint Brush Programmer
Hi everyone
I got a problem and i really need help as after I edited my images using a Paint Brush programmer, all of my images appear on a Paintbrush Icons. How can I change it back to JPG icon files?
Thanks
Hi everyone
Thanks
Hello there
When you save images using paint it will be saved as a bitmap file, with the extension .bmp. You can convert this image into a jpeg image anytime. Its simple, just right click on the image file and click on rename. Change the name from name.bmp to name.jpg where "name" is the name of your image file. This will change the extension of the file to jpeg as well as it's icon. If you want to edit the image again just right click on it and select Edit. Now it will open in paint.
I hope you are satisfied
It is a simple procedure to change back your images that are appearing in the paint brush icons back to the jpg icons, you will need to use the following simple procedure.
-Clair Charles
Thanks Charlie Charles. I followed your instructions and it was an easy task. I open the file using paint brush and from the file me , I clicked save as and saved it as JPG files. Thank you very much.
