lj rivera
50 points
Posted on - 03/09/2012
I am totally frustrated with the recent troubles of my PC.
What exactly is the reason to cause my PC freezes with Blue Screen Display, I don't understand.
Can I solve it anyhow?
Please suggest the right procedure to get rid of it.
Problem with PC Freezing and Blue Screen Display.
PC freezing is frustrating. Some causes are:corruption may occurred on the registry key,viruses,corrupted files etc.Your pc can be frozen too for low RAM or virtual memory. Programs require virtual memory to run well.
And that is why you should not run multiple programs at a time. Again my suggestion to you that uninstall some programs that are not important. You may run some programs or games without installing.
Your computer may get slow or hanged for more files in C drives. So please do not store any files in C drives. Be careful do not delete program files from C drives.
Then try to check your all files and folders and delete the unnecessary files. Scan your computer and delete the virus attacked files or program. All this action may help you without adding additional RAM. And again if you have not reinstalled your operating system for a long time then please reinstall it.
