A problem playing pogo games on a Mac. Every time I tried to open and launch a pogo game file in my Mac operating system, there is always this error that says unable to open file. What should I do? Why can’t I play pogo games in Mac OS? I need some answer.
Deborah Hall.
The problem you are facing is may be because of the browser you are using. If you are using Firefox or Safari browser you will have this issue because of a bug in it. So it's not loading plug ins because of the bug. The bug will be fixed in Firefox 12 and then you can play pogo games on much or try some other browser like Google chrome to play pogo maybe it helps because it's lighter and easier to use this browser and loads very fast.
