Problem playing video on KMPlayer on win7
I am using win7 on my desktop, But when I try to play video such as VOB, MKV or MP4 file format on this player it suddenly stuck and freezes. It often happens with high resolution file format.
So, any solution to this problems?
Answered By 0 points N/A #110112
First solution: You update your KM Player win7. Download the update version KMPlayer win7. Your older version can't support high resolution video file format You suffer the problem play video such as VOB, MKV or MP4 file format on this player it suddenly stuck and freezes its will be solved.
Second solution: You can use the software K-Lite Mega Codec Pack. When you install the software then select the option total video format click the tick mark option. You can play all type of video file with KMPlayer and support the high resolution file format. I hope you will be play video such as VOB, MKV or MP4 type of file format this player run it.
Answered By 590495 points N/A #313231
If your media player suddenly freezes every time you play high resolution videos like HD movies, it means your computer is low-end and it cannot support playback of HD videos. If you want to be able to play HD movies on your computer, you need to upgrade your system. Components of your computer that needs to be upgraded include the monitor, video card, RAM, and the processor.
Since this will cause you money just to be able to watch HD videos, one alternative is to use media players that can play HD videos on low-end machines. And the best media player to use on low-end computers that can play HD videos is MPlayer. To try this, download MPlayer for Windows. This will allow you to watch HD movies even on a non-widescreen monitor.
Also, try using VLC media player.
