I got a new playstation 2 and I am having a problem about ports. I want this to be fixed and I don’t have any idea on how to solve this problem. About playstation 2 port view instructions, I am having some confusion. To those experts, help me out of this.
Problem on playstation 2 port view instructions.
A Sony Playstation 2 has the following ports:
1. Controller ports : There are two controller ports in Sony PS2. These are the ports where you connect the controller or the joystick. If you want to connect more than 2 controllers then you will need to use an extender. See the image below:
2. Memory card slots : The Sony PS2 has two memory card slots; one for each controller. As it has two controllers, there are two memory card slots. See the image below:
3. USB ports : There are two USB ports through which you can connect external devices. You can also connect it to the PC using these USB ports.
These are the ports in the Sony PS2.
