avah.hannah
30 points
Posted on - 12/20/2013
Hi there,
I have been using Polaris viewer as my default explorer and I have downloaded some PDF files and Polaris is being set as the only application which can open them, how do I make Polaris not to be the default Application to open PDF files?
Problem with Polaris viewer in Galaxy Tab 2
There is a problem it might be possible that it is not available in your country that’s why you are not able to install Polaris Office on your device. You can figure out that on the play store under the error message.
If the problem is still there then just go to the device settings then under the application manager locate Polaris office in the list of the application, open it from there and clear all cache, defaults and data of the application it is problem of the device updating, Polaris office has been converted to Polaris viewer and it is now act as simple viewer application that can only be accessed when you open a supported file.
