Problem with portable Adobe Photoshop cs3
I downloaded a portable adobe PhotoShop CS3 program. Most of the tools work fine and all, but when I select the “Text tool” my computer just freezes up and everything hangs. My friend installed the exact same software, but when he uses his text tool its working just fine. Could anybody explain this to me?
Answered By 40 points N/A #82938
Hello Raven,
Reading your question above, i clearly get the idea that your may require cleaning up the disk on your hard drive. You can run the disk cleanup program to clean unwanted and temporary files from your PC. It will make your PC work much faster. Another way to make your PC work faster is to run the disk defragmenter tool from the system tools which you will find in the accessories button in the start button for Windows XP and in the Control Panel also.
For Windows 7, you may need to go to the Control Panel to use it or simply search by writing the name properly.
Thus your PC may work more smoothly, and Photoshop problems may get solved by then. Check the link:
If those process do not work, search the internet for free check up. several sites offer free scan and speed accelerator.
Here is a simple clean up software:
The disk defragmenter allows you to free up your hard disk space giving you more free memory to use to store, analyze your data. Following link may help you a little:
How to Defragment Your Disk Drive Volumes in Windows XP
How does disk defrag work?
The Adobe Photoshop is an application which requires more hard disk space than usual applications.
So it is recommended that you free up your system memory before start using the application.
