Problem on processing received messages
I'm having a problem on processing the messages I receive.
Some messages have apostrophes and / or quotations.
Some solutions are located at the forum.
Some features may be hidden or locked in your mobile.or u may be unable to use the mobile.just use up arrow button on android phones you can get the numbers option then once again press up button you will get symbols like , . / [ ] " : ' ; = – + _ etc
Hello?
This message mostly occurs if your phone as a problem.
Also note that if your Centre service number is not saved you might want to do that.
Also adjust your message settings; I would suggest you set them to default.
If the problem persists you might contact your network provider.
Amos Marie
