johnhegry
1180 points
Posted on - 08/02/2011
Hello friends,
I am here again asking for some help on PowerPoint issue. I received a presentation file made from PowerPoint. When I viewed its contents, I wanted to annotate some pages for discussion purposes. As I was about to make annotations, an error message appeared on my screen saying "cannot be edited because it contains a read-only-embedded font".
“This presentation cannot be edited because it contains a read-only embedded font.”
I am wondering why for so many PowerPoint presentations I received, this was the first time I got an error when I edited something. Please help me understand why I encountered such error message and what I should do. Thanks.
Problem with read-only-embedded font in PowerPoint.
Which PowerPoint version are you using?
If you are using PowerPoint 2003 – try to install Microsoft Office 2003 Service Pack 2.
If you are not using PowerPoint 2003 then you can upgrade it.
If you are using PowerPoint 2002 – you will open the presentation, click on "Save as", then click on "Tools menu" and click on "Save options.", click on "Embed TrueType fonts" and then click on "OK".
If you are using earlier versions, for example PowerPoint 2000 or PowerPoint 1997- open the presentation, on the "File" menu click on "Save as", then "Embed TrueType Fonts" and then "Save."
Now it should work.
If you are utilizing PowerPoint 2002, then follow these instructions:
Initiate the presentation.
Go to File, make sure to click Save As.
Go to Tools; make sure to double click {save options}.
Make sure to unclick the checked box under {Embed TrueType fonts}.
Go to File name and enter a new name while you click Save.
If you are utilizing PowerPoint 2000, then follow these instructions:
Open up the given presentation.
Go to file, make sure to click Save As.
Make sure to uncheck the {Embed TrueType Fonts} box.
Under the File name make sure to pick a new name while clicking Save As.
