Problem of reading XML math in the web
Hi everyone, I am doing web designing. I am working with XML on the web, but recently I can't read XML math in my web page.
Can anyone help me out from this problem, thanks!
Hello
You can use this example as reference: questions from Stackoverflow read xml contents-and-put-into-html-page-using-javaScript
You forgot to mention which programming language you use for making web site.
To successfully read XML file you need to write your XML file following certain rules.
To verify your XML file use this tool:
If your XML file have no errors then check if you use some special characters.
If so, then make sure you set text encoding in your XML file and in your web site on utf-8.
I hope I helped.
Regards.
