Problem receiving E-mails after upgrading Traveler Companion ver. 1 to 2
I have upgraded my Traveler Companion Ver. 1 to 2. But when I send E-mail from new version it is not delivered to the receiver.Â
How it can be fixed?
Many people just like you facing problem sending and receiving email when they upgraded Traveler Companion Ver. 1 to 2.I It is supposed that application may be corrupted or there are problem like mismatched setting.So,please first try to configure your application with correct data as for example:password,Id.,server address etc.If this method do not work please delete it at once.No problem you will find this on Apple App Store.Re-install it.After installation please configure your application with your correct information.I hope it will work well.
