Hey there everybody, I am facing a bit problem in using AMIBCP 8 bios codes editing  software. When I use it  I can not open my ROM files for my MSI board. Is there anyone who knows any program which will help me to get a back up ROM?Â
Problem regarding bios codes editor tool-AMIBCP 8
Hello Raymond,
It seems the problem is with the AMIBCP version. While loading the BIOS, it functions perfectly but when you try to save it, it simply crashes and hence cannot open ROM files. Please check the version of AMIBCP you are currently using and if possible use a same version of AMIBCP of MMTOOL for your MSI motherboard. The following links would be helpful for you.
https://www.sendspace.com/file/owfsdf
AMIBCP8 For Windows: BIOS Mod
