Johnson32
Posted on - 08/06/2011
Hello friends,
I am having a strange problem with my pc which running with windows 7 operating system.
My problem is that I can't copy or paste in any application like notepad,Microsoft word,Mozilla Firefox.
Both the right click & Ctrl+C operations are not working.
Guys need your help.
Thank you
nrahad51
5 points
Problem regarding copy & paste in windows 7
Well, it seems a pretty much tough problem. I am suggesting you some alternatives.
I hope those will do.
A. Is your pc is suitable for windows 7?
If your PC is not suitable for win 7, then you need to install the software that suits it best?
B.If you are using Office 2003 or any other version, then you can reinstall it again.
There may be some corrupted files for which the problem is occuring.So, it is better to reinstall.
C.Sometimes, there are some websites which do not have the facility for any type of copy or pasting.
So; you need to consider that too.
D.And, check for your PC's antivirus to bug problem.
This was a bug between machines running  on Windows 7 or the latest updates in Vista.
The same error in Windows 7 Professional/ RDP 7 was there too. It seems that the rdpclip.exe process is hanged and is need to be killed and restart it.
Also make sure that Clipboard Redirection is enabled on your system:
What you can do is to log on to your Windows 7 OS, type mstsc.exe and press Enter.
Click the Options button, click Local Resources Tab and make sure that the Clipboard check box has been selected. It will definitely fix the problem.
Good Luck!!
