I have a problem with leakbuster attached to my holdem manager. Now it is producing this error message that there is a problem retrieving the XML Data.
What is this XML data that it is referring to?
Will I be able to use this program properly?
Do I need to reinstall it again?
There was a problem retrieving the XML data:
Please provide me a solution.
Problem Retrieving the XML Data
Hi Tony S Boudreau,
It seems like your files are on read only mode and your internet access is cannot alter that .XML file that he is referring to, now, what you need to do is easy, just go to your source files of the file usually located at the C:/program files/whatever_program_that_is and right click the whole folder and uncheck the read only, apply it to all sub folders and try updating the XML file again
