The problem is with the Revo uninstaller setup
Hi Experts,
The problem is with the Revo uninstaller setup. I received an error message while uninstalling an application from my machine. Have a look at the screenshot below. I have no idea for the error message. Please help me to get a remedy of this problem.
Thanks in advance.
Unable to execute file:
C:Program FilesPDFCreatorPDFCreator.exe
CreateProcess failed; code 5.
Access is denied
Best Answer by Nicke Baker
Answered By 0 points N/A #192070
Hello Olivia,
Is this the only application that you have received such an error message while using Revo Uninstaller or you have got such an error message before? If you just installed Revo Uninstaller and you are using it for the first time then it is most likely that it did not install properly. You will need to retry the installation.
Nicke
Answered By 10 points N/A #192072
You need to login as administrator to uninstall or install a software. For this purpose you can run in Safe mode and then login as administrator and you will be able to make changes to the program or you will be able to uninstall the software from the PC.
Smith Thompson
