Problem with running .Bat file and Cmd.exe
I cannot run any .bat file. It shows- Bat file contain only Pause statement and it should return usual black window, and it also says "Press any key to continue…"
And after that when i press any key, nothing really happen.
When I try Start > Run > cmd.exe, a blank wind show up. But no prompt line.
If I try Start > Run > cmd.exe? It shows up normal help options, and after those black windows disappears.
After that, when I try to copy cmd.exe from my server to another windows 2003 server it shows the same problem.
Anybody can help me with this?
