Problem with safari browser-need not remember anything
I use apple safari browser as my main internet browser and I have been using it for a while. Recently I have installed a newer version of apple safari. I have in activated the remember history option which says that it will remove every history after each exit.
But it seems that the setting is not in action and opens the page I opened last time before closing the browser. Please someone tell me what to do.
Alden Clayton
Answered By 590495 points N/A #106585
Maybe the option got stuck and is already not working. This is often caused by corrupted data or file in the installation directory or an error in the hard drive’s file system.
Any of these 2 causes is true, it will still affect the function of some applications not only the Safari browser. Since the option is already not working even if you enable or disable it, uninstall the browser from your computer then check your computer for any possible errors. Use a disk utility application to check the system.
For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks. After checking the hard drive, install Safari back. This will fix any corrupted files in the installation and will restore the settings back to default.
Open Safari and then try browsing several web sites. After a couple of minutes when you visited enough web sites, try going to the settings again and enable that option again then close the browser afterwards. Open the browser again and check if it will still open the last web site you visited.
