Problem in Sage CRM 6.2 on Microsoft OS 2003
Good day! I am operating Sage CRM 6.2 on Microsoft OS 2003. While operating the assistance it shows a fault notification: "There are no 5.7 or modern CRM install(s) on this pc. The assistance until instantly stop" Can you please give me a suggestion about how can I solve it? I have attached a screenshot of the notification for your convenience.
Answered By 0 points N/A #144311
Dear Kristina,
       A CRM installation in 64bit Windows Server 2003 without making a changes to IIS, CRM won’t run by default IIS 6.0 win server 2003 64bit editioncan only run applications in, either, 32-bit mode, or 64-bit mode. Since the 'eWare.dll' is a 32-bit application, and the IIS default is for 64-bit applications, the following CScript needs to be run, on the server, from a Command Prompt: cscript %SYSTEMDRIVE%inetpubadminscriptsadsutil.vbs SET W3SVC/AppPools/Enable32bitAppOnWin64 1
or  Try installing CRM 5.7 maybe it can fix you’re problem.
 please do reply if this thread helped you 😀
