Problem on Samsung SM 943NW 19-inch widescreen LCD monitor
My computer has a built in ATI xpress 200 graphics. It has been functioning well in my old monitor. However, when I changed to a Samsung SM 943NW 19-inch widescreen LCD monitor, certain parts of the screen started to malfunction – out-of-focus texts, blurred images, etc. Can it be because the two are not compatible? Should I replace the graphics card of my computer already? Thanks.
Answered By 0 points N/A #114743
Hello Jazmine Theodore, I have read your issue on the malfunction of your Samsung SM 943NW LCD monitor. I had the same issue before when I upgraded or changed my monitor and use the ATI xpress 200 graphics. You can check the compatibility of these gadgets also on the booklets or the check the nearest store where you can check this issue. The ATI XPRESS 200 released date was 2004 so you can upgrade the GPU. This would also help fix the problem.
A new graphic card would also give a high-quality solution. The graphic card can also mean that it needs to be replaced also. This will provide a good result to the malfunction of your monitor.
