A problem with Samsung tablet video codec ac3.
Hi to everyone,
A problem with Samsung tablet video codec ac3. A codec is needed for my ac3 or Ace combat 3 video game. It seems like the sound was mute even if I turned the volume high. Maybe there is an audio issue between the Samsung tablet and the ac3 game, is the game compatible with Android Os? Please share with me your ideas and suggest some possible solution.
Your suggestion is very much welcome.
Answered By 0 points N/A #185885
I suggest you to check the following on your Samsung tablet.
>>Please check if you have downloaded and installed an original version of the game.
>>Check the audio settings for the game on your tablet.
>>If the issue still exists, try reinstalling the game on your tablet.
>>Certain games have compatibility issues with Android.
>>Read the installation instructions for the game.
If this steps does not help, contact the Samsung support.
Thanks and regards,
Skarbos Jay.
