Problem scanning in HP C7280.
Hello guys
I make an attempt to scan with Solution center to HP C7280. All are present on Windows 7 operating system virtual engine on an iMac. Without a problem I am able to print as well as copy with HP Solution Center but I receive an error message while trying to scan with another computer or software.
Tried to reboot, reinstall Solution Center, try to remove printer from iMac etc. When printer is connected via wireless it pops up an initial error message saying that it is not the same network and when it is installed in the Windows environment it proceed neglecting that error, all functioning except scanning.
Does the HP C7280 has a defect or is it the software? Any suggestions to solve this would be greatly appreciated.
Thanks in advance.
Error:
The scan cannot be performed because another program or computer is using the networked HP imaging device.Try again later.
Hide extended error information.4,[(0,400,80004005),(2,33,80040013),(3,33,0)]
