Problem with the sensor button
Sometimes when I place my finger on the Home button of my new iPhone 5S, the sensor doesn't work and a message appears to try again. What must I do to encounter this problem? Is it a common problem with such handsets?
Hi Adam,
The newly release of iPhone 5s encounter several negative feedback from users and critics. One of the issues that Apple should need to fix with their latest iPhone 5s is the consistent functionality of the iPhone sensor.
I believed that the cause of the problem you have been experiencing with your iPhone 5s is about the software version of the iPhone. To be able to fix the issue, you need to update the software version of the iPhone to iOS 7.0.3.
For detail information, please visit the website: iOS 7.0.3 fixes the sensor issue
For step-by-step instructions, please see: iOS 7.0.3 Knowledge Base
Ware
