Problem Solved In Zebra LP 2844 Label Printer
Why don’t my labels print correctly on my Zebra LP 2844 label printer? Please walk me through the steps, How to solve this problem?
This is an evasion setup:
Here are the steps to alter this setup:
If you can’t print a label properly with your Zebra LP 2844 printer, make sure the correct driver is installed. You can always download the correct driver for your device from the printer manufacturer’s website if you don’t have the setup CD. Go to LP 2844 Desktop Printer Support to get the driver. Download the correct driver for your operating system.
The Zebra LP 2844 printer has been discontinued on September 30, 2012 while service and support ended on October 31, 2015. Also, make sure the USB cable is connected properly to your computer when printing. Try transferring the cable to another USB port if you encountered a problem.
Notifications
