Hi! I badly need some help from you guys! I accidentally downloaded a very bad malware and I was unable to get rid of it. Some applications like Optimizer Pro keeps installing by themselves and it's totally annoying because once they are installed, I will manually uninstall them on the Control Panel and clean my PC with CCleaner and ADWCleaner. After this, everything will be back into normal. But after 3 or 5 minutes or if I restart my computer, same thing will happen again. My dilemma is happening for 3 days now and I really want a quick yet effective solutions for this.
Problem with some malware on my computer
Malwarebytes anti malware removal tool. Download the free version here https://www.malwarebytes.com/lp/lp4/02_r/?gclid=CjwKEAjw0LmoBRDHuo7UkaKXhn8SJADmDTG0UzC-lpc5kfu0LwxpLEgL5srIsiSKduam_HIthevRtRoCbI3w_wcB
There is a free version and a paid version, but I found that the free version works just as well.
The features for the free version:
Advanced Malware Recognition and Deletion of Viruses, Worms, Trojans, Rootkits, Dialers and Spyware
Blocks hacking
Blocks malware in real-time
Blocks phishing attempts
You can also schedule automatic scanning
Blocks malicious websites
Compatible with your own anti-virus
System Requirements:
Windows Vista/Windows7/Windows 8/Windows 8.1 (32 bit or 64 bit)
Windows XP (Service Pack 2 or later, 32-bit only)
Internet Explorer 6 or newer
Below are some screenshots of setting up Anti Malwarebytes
