Jean Moore
10 points
Posted on - 07/23/2012
Hello everyone
I have HP Z800 with dual intel Xeon E5530 2.4 GHz and 24 GB ram. I have SAS 320 GB@ 15 K RPM OS hard drive and 1TB HD with 1.5 TB HD internal. I also have Nvidia Quadro FX 3800 and I am using Avid media composer 6.I have recently installed Sorenson media from the following website:
http://www.sorensonmedia.com/squeeze/squeeze-desktop/downloads/
Previously I had been using squeeze 8 Sorenson media lite version. When I tried to install the software from the above mentioned website, I got an error on my screen. The screenshot of the error is as follows:
Self-Registration Error
The following files did not self-register or unregister:
1. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_aac_ds.ax
       The specified module could not be found.
2. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_amr_ds.ax
3. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_avc_ds.ax
4. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_dv100_ds.ax
5. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_dv50_ds.ax
6. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_j2k_ds.ax
7. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_mp2v_ds.ax
8. C:Program Files (x86)Sorenson MediaSorenson Squeezemc_dec_mp4v_ds.ax
<More files….>
To continue, click OK; otherwise,click Cancel
                                        OK           Cancel
I searched a lot for the squeeze 8 icon on the desktop and also in the folder but I couldn't find it. I have also attached the screenshot of the folder:
Please help me in fixing the problem. your suggestions are required in this regard.
Looking forward to your response
Kind regards
Richardson
Problem with Sorenson Software Installation
Dear User,
It seems that the performance of your pc is suitable for the application
The error you mentioned above could be a result of file corruption or missing files.
I suggest you to uninstall the installed parts of the application completely
And then download the setup again and install it. And when you are downloading make sure you download the windows version.
Thank you. Â
