Nina Hayes
Posted on - 02/23/2012
Hello
I am facing a problem in getting Direct X to start.
Already I have opened the Direct X controller and the image I added is what I have seen.
I am using a laptop and I don’t want to take to any hardware specialist for repair.
Any tips?
Need your suggestions.
Thanks a lot.
Problem starting Direct X on my laptop
Video Card check:
Several programs run real slowly, or not at all, unless Microsoft DirectDraw or Direct3D component speedup is inverted on.
To learn this, go to display tab under DirectX Features, account to see whether DirectDraw, Direct3D, and AGP Texture acceleration happen as Enabled. If no, then turn it on.
Go to screen resolution through start button, click control Panel, and then, under Appearance and Personalization, adjust screen resolution.
Move to Advance settings.
On Troubleshoot tab go to change settings. Type password if needed as administrator.
Push the Element Speedup someone to plentiful.
If it doesn’t work, you have to update the video card driver or card itself.
