Problem starting Windows Operating System
Asked By 7060 points N/A Posted on -
I tried to start Windows XP I received  the following error message: Error message#
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk. Check boot path and disk hardware.
Please check the Windows documentation about hardware disk configuration and your hardware reference manuals for additional information."
 How can I resolve ?
Best Answer by Smithsan
Answered By 0 points N/A #79866
This problem can occur if:
1) Default value of the boot.ini file is wrong or missing.
2) XP is not installed properly.
3) Some problem with your hardware.
4) boot.ini not containing proper partition path.
There are several ways to resolve this issue:
1) You have to edit the boot.ini file with the proper & accurate default value.
2) Run the recovery console & try to use boot configure utility
3) After starting your computer go to BIOS settings & run the DSKCHK service, that can fix your problem.
I try to solve your problem, if any more help needed please let me know.
Thank you
Best Regards
Answered By 0 points N/A #79867
When the Start Files in the operating system have problems, these errors will appear, therefore the solution is to install a new operating system.
If this error occurs again, it is recommended that ask a hardware technician for help.
