thekrystic
Posted on - 10/04/2012
I'm finding it difficult to stream radio. Specifically, it's a Hindi URL as I want to stream in such music. I have Windows 7 with a Google Chrome web browser and lately, when I try to stream in music, especially this type, it takes quite a while and it slows down my computer. Do you have any advice?
Thanks,
Jeff
Problem – Stream Radio Hindi URL
A lot of factors would affect online streaming, some are: un updated browser, internet speed/bandwidth, P2P downloading, computer/PC memory. Those are the things that can affect your streaming. Try to update your browser/ try to erase some memory by erasing your browser history:
1. Open your Google chrome and you can find this
button at the upper right corner of the screen, click on that.
2. Then select Tools.
3. Clear browsing data.
3. and there you have it, you can delete browsing data on your own preference.
Another thing, if there's nothing wrong with your internet speed, you can always switch to another browser, like Mozilla Firefox (Always update). Clean your pc regularly by using software utilities.
Hope this helps.
