Problem of studio 700 pci Windows 7
Hello everyone. I'm having a difficulty about studio 700 pci windows 7. How to run this studio 700 pci window 7 without pinnacle studio 11 & 12? Thanks for the response.
Hi Alison,
Using Pinnacle Studio PCI -700 capture cards without studio 11 or 12 may cause your computer to crash dump every time you try to capture analog video signal even when using the latest Windows 7 capture card updated drivers from Pinnacle.
When using Pinnacle Studio Programs with Pinnacle hardware capture cards you must continually defrag your hard drive and constantly reboot your computer.
When you start to capture please don't get out of sync or in sync audio capture when capturing in MPEG2.
If you want to capture the best possible picture quality you must only capture in AVI uncompressed video format this will use much hard drive space.
