cperez
Posted on - 10/31/2011
Hi all ,
I want to play Tiger wood 2008 on my computer with a Windows Vista Operating System. I inserted the disc into my DVD/CD/writer drive but its not loading and its not seeing any disc on the drive.
But when I try it on other computer XP or Win 7 it loads and Autorun shows up. I need help guys!
Thanks
Problem with Tiger wood 2008
There's no problem with your computer if compatibility issues are concern. Windows Vista is pretty much compatible with Tiger Woods PGA Tour 2008. Since the disc is read in other computers and only yours seems can’t read it, your CD/DVD drive may only be dirty. Maybe you already inserted too much disc and its lens got dirty already. It is inevitable. You just need to clean it using any ordinary CD lens cleaner. If you have a CD cleaner for your CD, VCD or DVD player, you can use it to clean your CD/DVD drive. Your disc will be detected again after the lens is cleaned.
To further learn about its system requirements, you may read the information below:
Windows XP, Windows Vista
Pentium 1.6 GHz or higher processor
256 MB RAM
3 GB available hard disk space
DirectX 9.0c
64 MB ATI Radeon 8500 or NVIDIA GeForce3 video card
Sound card
8X DVD-ROM drive
56 KBPS internet speed for multiplayer requirement
cperez
I've looked up on the system requirements that you listed. I noticed that i need a higher processor,
I changed it and cleaned also the CD/DVD drive.
It runs smoothly now.
Thanks Sharath Reddy..
