Hello experts,
Problem with top eleven game occurred. I want to run the game in my dell laptop with an operating system of windows 7 starter. And suddenly crashes and never continue to load through the game. What will be the possible cure or solution for this kind of problem? Please do help me.
Thank you.
Hello Mellisa,
Are you sure the setup that you are running is meant for the windows 7 starter? If it not then the error that you are getting is probably due to compatibility issues. In order to resolve it, you will need to go to the internet and download a game eleven app that can work on windows starter.
Nicke
Hello wright,
If you don't find any clue that might occur this crash, you may uninstall the game and spent the time reinstalling and it will fix the problem immediately. You may get the update version from the web and fix the problem.
