Problem in transferring mp4 for blackberry
I got a problem using mp 4 for blackberry. When I transferred the mp 4s to my blackberry, no video has shown but the audio is working properly. What seems to be the problem?
Hello Berth! Good Day!
As far as your concern, yes! Blackberry does support MP4 videos. However, MP4 has several codecs just like other video file format and not all codes are supported. The codec of your MP4 Video isn't supported that is why you can only hear the audio.
Feel free to visit this Blackberry website for you to know the supported media types and its codes in you mobile phone.Â
Hope this helps!
Hi Berthatcummings!
I found the answer about your problem.
When I surf the web many answers comes out but the best answer is here it is a tutorial to learn it immediately.
You can also have this site for downloading the html:
Thank You!
1. If you have desktop or laptop availability go to below link and download software for free and follow instructions:
https://www.dvdvideosoft.com/products/dvd/Free-MP4-Video-Converter.htm
Sure you may get solution otherwise.
2. I have searched so far find blackberry related forum.
It may helpful for you.
