Problem trying to run ror.exe to debug
Hi friends, I am having problem when I am trying to run ror.exe to debug. It is just refusing to see the config file and render type. I am using VC++. on my Windows seven PC. Why this is not being able to read plugins.cfg?
Unable to load the render systems. Please check if all required files are there and the plugins.cfg file is correct.
This is a fatal error and the game will not start.
Answered By 10 points N/A #153926
Hello John,
It seems like that application was changed so that the configuration can be able to extract the skeleton by itself. In the event that screen just stays black, it is more likely that your GUI does not work properly. They is usually a menu is such a case.
Another workaround that you should try out and see if it will help resolve that issue is the following:
  • Go and get plugins.cfg,
  •  And then put it in the following folder location on your computer: C:Program Files, or Program Files (x86, in case you have a 64-bit operating system.
Hope this helps.
Carl
