Problem in uninstalling a Logitech webcam
10 points
Posted on - 05/05/2012
Hello everyone,
I am having a problem in uninstalling a Logitech webcam. When I am trying to uninstall the Logitech webcam, I find an error at the end of process that says “uninstall failed” and then uninstall process does not progress further so I have to abort the process.
By aborting the process, all my system icons disappeared and I had to restart my system again. When I restarted the system, the windows gives the message“C:/Windowssystem32systemprofileDesktop refers to a location that is unavailable”. Is there any possible way to uninstall that software which does not disturb my system files?
Thank you in advance.
