Hello Techyv users,
I have problem with unsubscribe plugin apple mail. I want to uninstall it from my Mac OS X PC. Whenever I tries to Uninstall it my system gets freezes and I have to restart the system. This happened a few days ago after my system crash occurred. Please help me out uninstall it.
Problem in uninstalling unsubscribe Plugin Apple mail on OS X11
Hello Jaay Ferocity,
I hope so that you are getting this thing by using the default uninstaller then you have to use a third party software. For deleting files you can use the software names as "REVO UNINSTALLER". That is easy to use and you can delete or uninstall thing through it from your Pc in a easy way. Given below is a link download any version of the software from there.
https://www.revouninstaller.com/
Hello Jaay,
I believe you are facing a problem while unsubscribe apple mail and you also want to uninstall it from your MAC PC. Have you tried the default software to uninstall or did you try any third party software? Generally plugins are used to increase the functionality of apple mail but sometime two plugins might clash and you wont be able use both together. Some plugins are designed for a particular OS and you might find it difficult to use with other versions of Mac OS. Please check your plugins before uninstalling.
I hope this helps.
