There is a problem with updating new devices in my computer. When I check Device Manager I just found a yellow triangle over Microsoft isatap adapter, #2, #3 and also teredo tunneling adapter. Windows shows no error when I re-install the device using Device Manager even then it shows “good” sign foe that device.
Unfortunately windows updating client shows I have no new updates in order to download them.
Problem with updating new devices in Windows
Issue
When you open the Device Manager in computers with the following operating system – Windows Vista or Windows Server 2k8, a yellow exclamation mark is visible adjacent to Microsoft ISATAP adapter. On further analysis the following message will be displayed “Windows cannot load driver (Code 31)” when properties dialog box is opened for the device.
Resolution
The issue has been well accepted by Microsoft and they confirm that it can be ignored without any expected complications. The yellow exclamation mark does not signify an underlying problem with the device and the functionality of the device is not affected at all.
NB
This is a known issue and Microsoft is well aware of the same.
Hi there,
It seems you are having trouble downloading updates for your devices. If you can’t update manually by going to Device Manager I suggest you search in Google for its driver for your corresponding operating system (Windows 7 or Windows XP) and download and install it.
If you can’t find the driver this time also try downloading and using 3rd party applications so that you can sit and rest while it searched for the updated drivers and install automatically.
I suggest slim drivers personally. You can download slim drivers from Driver Update. Now install it and let it to scan, after installing corresponding driver make sure you restart your PC to successfully run your device.
Hope that solves your case.
